blox IM into gsr eg help!!
ok i just want to know if i could use the stock throttle body on the new blox IM, the throttle cable bracket is way to the right on the blox manifold, it seems kinda far to take the throttle cable all the way to the throttle body, should i get an itr throttle cable and bracket or can i use my d16z6 bracket with the stock throttle cable and gsr throttle body?
Re: blox IM into gsr eg help!!
you can use the stock throttle body and YES you can use your D16Z6 throttle cable bracket. if you want this to work, snag the THROTTLE PULLEY OFF OF YOUR D16Z6 also and put it on the GSR throttlebody. this is because the GSR throttle pulley is different and will not work with this setup. HERE IS A PICTURE:
good luck.
good luck.
alright thanks a lot, i'll try getting the itr bracket and cable later but i just wanna finish the install for now.
tegsallgood
12-18-2004 12:14 AM
1SIKCRX
07-01-2004 08:06 PM
