problem w/ passenger headlight
my passenger headlight is really dim
this happened after i hit a deer
i put a new headlight housing on,new bulb,and even a new plug for the bulb and it's still dim
i even checked the fuses and they're fine
i dunno what it could be
any help would be greatly appreciated
thanx
thanx
Re: problem w/ passenger headlight (ebp 99 si)
check the connections.. i once had a dim light.. i played with the wires connected to the bulb and the bulb lit up like normal.
Your ground connection to that head light is bad. Test it out by connecting a ground wire to the headlight. You can run a ground wire anywhere from the chassis to the head light. Ground wire to the head light is black.
check the other lights. i was installing a headlight on some lady's accord and i was having such a hard time to the dim light effect. i was checking fuses, checking wiring, checking continuity, it turned out it was just another headlight was burnt out also making that one dime.
Re: problem w/ passenger headlight (IVI)
i checked the other lites and they're fine
i've had 3 alternators on the car in 3 days and it still wont' run
the battery is fine
the weird thing is the car starts up fine and idles but when i go to drive it the batt. lite comes on and the car shuts off
the battery is fine
Re: problem w/ passenger headlight (=GAMEOVER=)
no corrosion or looseness
i did finally fix the pass. headlight
but the car only shuts off after it's fully warmed up
it will sit and idle forever but i drive it for like 5 min. and the batt. light comes on and shuts off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI »</TD></TR><TR><TD CLASS="quote">would you like to share with us what caused the problem with the headlight? or will it be your little secret.</TD></TR></TABLE>
i hit a deer a while back
i did discover something new today
after the car's warmed up the red light on the msd digital 6+ starts blinking and when i go to rev the engine it about chokes and dies
what does hitting a deer have to do with replacing headlights and using 3 alternators? what was the cause? did the deer get stuck inside your headlight and unscrew the bulb? or was he blocking the beam and thats why its dim?
obviously you have a problem with the ignition. your not getting a correct spark if your cars starting to die out or sputter. check the system. what does the light mean?
WRTEG
08-25-2004 06:25 AM
