need help, Dx to Z6 question
hey guys i have a 94 dx hatch that i put a z6 motor in. i have the p28 but i need to add wires for the vtec oil pressure sensor and the vtec solenoid. how exactly do i do this?
Re: need help, Dx to Z6 question (hatchback_al)
search, but I won't be dick take vtec solenoid wire and run it to the A4 plug (make sure you get some harness plugs) take vtec pressure switch run one wire to the ground (good place is thermostat housing bolt, doesn't matter which wire you use), take the second wire from vtec pressure switch and run it to the D6 plug (use ECU harness plug, just like for vtec solenoid).
http://www.hybridgarage.com
TSPeed Factory
Re: need help, Dx to Z6 question (shaundrake)
A4 and D6 just refers to the pin location on the ecu plugs. but basically you want to find a donor pin and add a wire to it and then stick the pin into those pin locations. A4 to the VTEC solenoid and D6 to the VTEC pressure switch.
TeamRPM_ZC
07-14-2008 08:36 AM
CIVIC96DXcp
05-07-2005 09:27 AM
hatchedzex
04-12-2004 02:41 PM
jdm169
03-13-2003 05:39 PM
