what do you need for a complete home made turbo kit?
im building a turbo kit, and i dont know if ive gotton everything, can some people run down a list of what the nessecities they have for the kit. parts wise, not tuning. thanx
Re: what do you need for a complete home made turbo kit? (hatchedzex)
check out http://www.homemadeturbo.com and check out their setups.
ex. manifold (cheap or expensive whatever takes your fancy)
turbo (size and output)
wastegate (size and spring)
piping (charge pipes)
plumbing (oil lines and fittings and vaccum lines)
bov (optional recommended)
intercooler (optional recommended)
fuel (fmu, vafc hack, injectors, pump ect.)
that's just to start with a basic system... you'll probably end up with more stuff.
good cheap turbos can be found at junk yards on svo mustangs and turbo tbirds, they come with garret t3 turbos and a friend of mine picked a good condition one up there with the manifold for 100$
Re: what do you need for a complete home made turbo kit? (pb16b)
i have a turbo from a 626, its small and will spool insanly fast on my d16, im looking for a 1g dsm bov, my turbo is internaly waste gated, im gettin my ecu programed, im only going to run no more then 6psi. also will dsm injectors plug into a civic harness? if the waste gate is set at lets say 7psi but i only want 5psi how can i turn it down? usuing the boost controler?
anyone running close to this set up?
Gold DA9
10-05-2010 01:04 AM
AL ASPIRATED
05-09-2004 09:48 PM
