problem in my 94 coupe
So this just started a few days ago.... at random times, my car has a squeeking sound near the front drivers side tire im assuming. The sound increases with speed... at first it sounds like air coming out, like a "pssshhhhtt..." kinda sound. But its been about a week, and the tire is fine. At a dead stop it doesnt do it, and like I said, will start and stop at totally random times...sometimes will last a minute, sometimes 5 minutes...when I push on the brakes it stops, this is the weird part...anyone have any clues?
does it make like a ts ts ts ts ts ts when your driving.. because my coupe does that as well and when i press the brakes it stops.. i think my rotors are warped.. its something to do with the brakes i beleive
Re: (JDM EJ1 95)
yea kind of, the only thing is....its not constant, it starts sometimes and ends at random times...for instance, driving home from work today it happened for 2 minutes or so...but yesterday driving 160 miles, it didnt happen at all. The day before that, it did happen .. Im confused.
Re: (pburke23)
I had a squeak come out the front driver side of my 94 civic ex, thought was the the tire or something, but i have new brake pads and disks so I decided to look at the belts and my power steering belt is cracked up to hell, replaced and no more squeeks
Re: (StrikerX)
Brake pads is my bet. Same thing happened to mine. Put new brake pads on, and was later told I should've used some kind of brake pad grease or something. It's the brake pads lightly touching the rotor.
Re: (ShakesTheKlown)
any clue why it only does it at random times then? and goes away? I would think if it was pads, that it would be constant....am I wrong?
Re: problem in my 94 coupe (IVI)
*shrugs*
I'd assume it's because they aren't bolted into one specific place. They've just got a thin metal bracket holding them down, so I'd think they have a little free play. If you brake hard while going at a decent speed does it stop for a while?
Re: problem in my 94 coupe (ShakesTheKlown)
I have the same car with the same sound. I refuse to use the word problem because it's not doing any harm. Shakes has a good theory. My theory would be expansion and contraction from the temperature. But my brakes work fine. I autox on Sundays and haven't had a braking issue yet.
ibe2fly
01-15-2005 10:24 AM
