strippin the back interior need help!
is it easy to strip the back interior of a coupe (99) civic, need help on this guys cuz want to know the exact way of strippin out this interior
Re: strippin the back interior need help! (bigBOI_palooza)
it's relatively easy. start with the rear seats. the cushion is held in by a bolt in the driver side on the back. the seat back is held should be held on with a clip to prevent the backs from sliding out. remove the clip and slide out the seat backs. the remaining panels are held on by a couple of screws and pop right out.
Fole the rears down. At the bottom of the rear seats there are some brackets @ the end of each seat cusion. Take out the seat backs by loosening those bolts. The cusions will slide right off. You can then take the brackets off from the body of the car. You will the move to the seat bottom. There is one bolt about 1/3 of the way over starting from the driver's side. Loosen that. The bottom cusion should snap right out. It requires a little force back & up. If you want to remove the plastic paneling, you can pop off all of the plastic pins that hold them on. A trim panel remover work really well for this. That's all for the rear seats and side panels.
rawrjaay
09-08-2011 05:33 PM
