cruise control help
cruise control help
ok, i bought a 95 ex rollover, switched everything from the wiring harness to the dash/carpet, everything into my hatch... everything works but the cruise control, the fuse is fine so whats wrong? is there something i should check? i'ved tried pushing all the buttons in any/every sequence....
Re: cruise control help (IVI)
i'm not sure what the problem is, one thing i've been thinking, does it have to have the p28 ecu or anything like that? i'm just using a p05, im not sure what to check to see if its doing anything
Re: cruise control help (stingray2772)
I bought a cruise for my hx that was supposed to be off an EK ex, well it turned out it was for an EG civic with auto tranny. I know this cause the box had p28 at right on it.
im doing the same thing to my hatchie. did your engine bay have the cc plug already located along the inner fender? mine does not so im wondering what i need to splice into etc etc. did you also add the actual power button on the dash, not the buttons on the steering wheel.
Re: cruise control help (gambo117)
i bought a 95 ex roll over, i switched the entire harness over so im not sure what your missing, i threw the different entire steering column and wheel with the buttons, as well as the cc button on the dash
Honda24noobish
07-11-2010 07:30 AM
