del sol side skirt problem?
Re: del sol side skirt problem? (szwarc28)
can you read?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy del sol »</TD></TR><TR><TD CLASS="quote">double sided tape ? </TD></TR></TABLE>
why dont you contact the company from which you bought these side skirts
Re: (ShadyEH2)
gdybys zrozumial ciemniaku co do ciebie pisze pewnie
bys chcial mi skopac dupe
a tak huja z tego wiesz i gowno mi zrobisz
wiec zamknij sobie ryja i spierdalaj z tego topica
zebys nie zasmiecal strony
twoj zasrany interes jak mi ktos pomoze
nara
nara
Re: (B16Drag)
3m works and if you are doing it yourself you will probably screw some screws through the side skirts into the wheel wells. I molded mine when I had them in my opinion it is the only way thay will stay or look decent.
you will fiend that unless you have a body kit pout on professionally(im guessing you found the cheapest one you could fiend thinking they are all the same it will cost thousands to get it pout on right) it will never fit right. as well as it will fall of if you pout it on yourself. so it will make your car look cheep in the long run. it also pouts a big pull me over sign on your car for cops.
no one likes likes them because they cost to much for no function and thay give the the "fast and furious" stereotype.
so if you ask about body kits on hear you will get A$$ hole remarks all day. if you want a body kit I would fiend another forum more opened mianded. I love H-T but we are all brain washed hear!!!
Just drill some screws into it and cover the screw heads with bondo or somethin. Or take it to an autobody place to have the work done if its too complicated. 3M double sided sticky tape works great too but only if the car is not driven much...
Re: (bbarbulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo »</TD></TR><TR><TD CLASS="quote">not brainwashed... enlightened </TD></TR></TABLE>
Del Sol on Steroids
10
07-12-2007 04:15 PM
