getting gasoline from exhaust
everytime after a drive i look into my exhaust and there will always be specks of gasoline in my exhaust...i need to know why this is happening
Re: (bbarbulo)
Are you sure it is gasoline???
Do you have a cat. converter or did you take it off???
Is your timing adjusted properly???
Is your O2 sensor working properly?
All these can be the problem...
How do you drive mostly? High revs or low???
Try to wind the engine a bit if you haven't recently... under "wind" I mean go on the highway and drive in 3rd or 4th gear on aprox 6000 rpm (whatever does not brake the law) and keep the rpm steady (no oscilation)... drive like that for 5-10 minutes...
After that, check exhaust again... there should be no gasoline anymore...
Re: (KKVTi)
when i bought my car i think the guy adjusted the timing forward a little so i dont know how much to adjust it back...it must be the timing...anybody know where to adjust it to stock? no advanceing no retarding?
