brake smell?
brake smell?
hey everyone i just drove to the mountains and just got back, anyways my car smelle like burnt rubber. im guessing it is either my tires or my brakes, but i think its my brakes. anyone have any idea y this happen? im pretty sure its my brakes though because on my way down i had like no brake, i hadda push down really hard just to slow down a tiny bit so i was braking really early and people were passing me up. anyone know y this happen? and will it just go away after a couple of hours or am i going to have to replace my brakes?
Re: brake smell? (lakers6902)
yea it should, happens to a lot of ppl.... i am always up in the montians and its happen to ppl left and right, plus my parnets car but everyone was fine after a lil
it if stays could be something serouis
Re: brake smell? (snowdogg)
ahh ok, well wen i go to school (yea im still in school) ill see if i have more brake or it still smells, hopefully it went away if not, you thinik i should just replace my brakes?
its probably from your brakes heating up from using them so much... do what the other guy and use a lower gear if you can... also if you're driving and start to smell that you should usually pull over to let your brakes cool off
Re: brake smell? (amy del sol)
you over heated the brakes, when brakes heat up they are much less responsive. especially under heavy loads and steep inclines aka mountains. definitly use a lower gear and if that happens again let the brakes cool off. high heat also damages brake components.
I agree its brakes overheating. And if youre gonna be drivin the mountains alot you might wana consider a brake upgrade. Such as better rotors and pads. That way you dont loose the brakes for good next time.
