hey SOHC guys, need some tranny advice
ok im having a hard time getting my car into gear at full boost, i hate how sloppy sohc trannys are, i ahve the energy suspenson bushings but that doesnt seem to help. i dont want to keep grinding it trying to get it in gear, but i loost alot of time when i miss.
any suggestions?
tranny is a Y8 btw
any suggestions?
tranny is a Y8 btw
Re: hey SOHC guys, need some tranny advice (Timmay)
es makes the inserts for front lower 2 mounts (left & right), and the rear mount. do all three, it's a great upgrade.
D series shift linkages suck ***. a heavy **** like the skunk2 might help your cause out a little. i'm not a fan of short shifters, but one may be worth considering.
Re: hey SOHC guys, need some tranny advice (jwn7)
i have my 2 lower mounts(frame ones) filled with window welder stuff, so they are stiffer, but all the other mounts are stock
so if i am understanding correctly, (correct me if i am wrong.) You cant get the car into gear when you are moving right? and dose this acure only when the car is moving, or always? cause i had the same problem and i just put gm syncro mesh in and then i could put the car back into gear even just fine. also do you have a pic of the mounts that you are talking about? i want to do some mounts to stiffen things up. and what is this window stuff you are talking about?
Re: hey SOHC guys, need some tranny advice (sohcvtec1995)
i only have problems shifting at high boost, I.E 15 psi, im gonna try mount inserts,
the stuff is called window welder, its for windshields its urethane base stuff, works ok
Risky Business
Like I said online, your motor is shifting backwards like a rocking chair under boost, when you try to shift the motor flexes forward and it is hard to get an accurate shift. Get the ES inserts and put the rear one in or you can use window weld as said before. I have the ES rear insert in and I love it.
It's not the high boost but the high RPM's that's making it hard to shift into the next gear. The transmissions synchro's slow the gear down enough to engage the next one. As the synchro's go bad, it takes longer to slow the gear down enough to get into the next one.
In other words, it's probably your synchro's going south. 3rd gear synchro seems to go out first from my experience. It only takes a few hard miss shifts to damage the synchro's permenantly. There's a few shops around that will now put in carbon fiber synchro's and it's supposed to dramaticly improve high speed shifting.
Also, GM synchro mesh works good (Adds friction to the synchro's at higher speeds to slow the gear faster) if you haven't done to much damage to the synchro's already.
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">ok i got some of that, damn 10 bucks a quart</TD></TR></TABLE>
It was like 11.50 for me
Re: hey SOHC guys, need some tranny advice (BauleyCivic)
how does this stuff compare with BG Sycro SHift????? I am running the D15B LSD tranny with just HONDA MTF should i use this gm stuff??? or b4 i used BG sycroshift.. and somehow my bearings went bad in my old tranny????
I got mine at GM parts direct for less than $7 dollars a quart but you need to buy 6 at a time. Atleast you'll have some to change it out later.
http://www.gmpartsdirect.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">you can also get the pensoil syncro mesh. Just go to your auto parts store, or even walmart.</TD></TR></TABLE>
i work at walmart, i dont belive we carry that
i work at walmart, i dont belive we carry that</TD></TR></TABLE>
i meant to say kmart, cause they were like pensoil sponsered or something like that. But only the ones that have the car repair bays.
ABlais
12
06-17-2008 11:25 AM
crashtest Sonny
12-31-2003 10:57 PM
