P28 speed wire = what color wire? (RSM)
TSPeed Factory
Re: P28 speed wire = what color wire? (Louie_EM1)
http://www.apexi.com should have a wiring diagram.
Guest
Posts: n/a
Re: P28 speed wire = what color wire? (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">The VSS wire is Yel/Blu, pin B10.</TD></TR></TABLE>
Thanks man!
Thanks man!
Guest
Posts: n/a
Bump!
pin B10 - Can anyone help me with that, I don't quite fully understand.
I thought the yellow/blue was enough, yet I found a blue/yellow from my p28 as well as from my OBDII->OBDI harness.
So I just need someone to quickly clear the air (SORRY FOR THE QUALITY!)
My normal ecu wires as well as the OBD conversion harness:
(bottom part = ecu)
(top part = after conversion)
Here's the yellow/blue wire from my p28:
Here's the yellow/blue wires from my OBDI conversion harness:
Both blue/yellow wires the same? OR should I go with the one on the ECU or the one on the conversion harness, reason why I am asking is that there's A LOT of slack after the conversion harness (as you may see, my VAFC is spliced that way).
THANKS!
Bump!
(bottom part = ecu)
THANKS!
Civic_EX_turbo
10
11-09-2005 10:36 AM
