yet another AC question RE: compressor relay wires/electrical
okay, the compressor relay has 4 wire leads.
1) White 12V+ constant on (from underhood fusebox)
2) BK/Yellow 12V+ ignition on? (blower motor relay)
3) Red power to compressor (powers compressor)
4) BK/Red to ECM/CPU (ECM pin A15)
so...
#1 self explanatory
#2 seems to be on contsant when ignition is turned on
#3 when 12V+ is applied, the compressor clutch engages.
#4 I don't know what this does. I stuck a test light into it (at the main wire harness side) and the compressor clutch engaged??? also the test light lit up, so its a 12V+. When i stabbed the wire near the relay, nothing
is #4 a 12V+ signal to the relay to close and power up the copmressor? Is it intermittant? (dependant on cabin/AC temp?)
at any rate using the OEM relay doesnt work so I wired it up like this:
1. relay switch is powered by tapping the condensor faN 12v+. Fan goes on, compressor runs. fan stops copmressor stops.
2. ground it to the chasis
3. 12V+ in - constant goes to one lead on the (aftermarket) relay
4. 12V+ out - goes to the compressor power.
should i use another source for the relay switch power (#1)? like #4 which i suspect is a 12V signal wire (not constant)
any input is appreciated.
so...
#1 self explanatory
Promisering
10-10-2018 04:40 PM
akb427
Honda Civic (2001 - 2005)
06-28-2013 08:51 AM
