Suspension(LCA, Shock, etc)
Alright I have a stock 2000 CX......I have Koni's here waitin for GC's. I'm looking for front and rear disc brakes and came across a 5-lug with ITR LCA's. I've read through searching ITR LCA's will not work on my car. What LCA's am I looking to get to install a CTR sway bar. I've been searching all different LCA and sway articles and nothin just flat out tells me. Please point me to a link or just tell me what I need to use.
I believe I know I can't use ITR LCA's. What LCA's can I use to mount up a CTR or Comptech sway bar and keep the set of koni's I have for my hatch?....I'm gonna guess SI LCA's....but wanna be positive tryin to get this all put together smoothly..5-lug, Koni's and future rear sway bar
Re: (zyzyx6969)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zyzyx6969 »</TD></TR><TR><TD CLASS="quote">did you drill a hole on your LCA</TD></TR></TABLE>
they come with holes in them
Re: Suspension(LCA, Shock, etc) (zm_dawg)
yep just keep your stock lcas, as they already have the holes predrilled. there's no need to blow a grand on a useless 5 lug setup when what you have is sufficient enough. keep that and get the comptech bar
as for the rear disc conversion, you want to get ebrake cables, both rear trailing arm assemblies, and the master cylinder from a 99-00 si. you don't need the prop valve or brake booster. double check what you need anyways: http://www.slhondparts.com, because i'm not 100% on what you need for the brake lines.
and the fronts, you could get ex/si brakes if you want, because it would be the cheapest and easiest upgrade; but better pads and new rotors will do you justice enough.
snowboardgeek1
08-15-2014 06:46 PM
snowboardgeek1
Suspension & Brakes
10-14-2006 10:27 PM
spyz34
01-29-2005 10:37 PM
B_CRUZ!
07-09-2003 05:35 AM
