NEED HELP?
Old Aug 29, 2006 | 03:32 PM
darkblue1998ls's Avatar
Default NEED HELP?
i HAVE A 99 CIVIC DX AND i AM CONVERTING TO OBD-1.I got the conversion harness and the ECU wich is a p06 from 92-95 civic dx models.I plugged it in and started and it idle's like **** and jolt's the car if I try to drive it.I checked the cell for the check engine light and it is throwing 14 wich is the IAC(idle air control)valve.I have also unplugged it and tryed to run the po6 but it still threw the code.What could be the problem?Maybe a wrong wire on the conversion harness or a problem with the ECU?
Ivanek00
Engine Management and Tuning
Mar 15, 2009 11:07 AM
bambbrose
Oct 9, 2004 08:27 AM
xXx Justin xXx
May 13, 2002 04:25 PM
