idle acting up...
Old Aug 29, 2006 | 05:21 AM
HNP's Avatar
HNP
Default idle acting up...
whats up h-t, my idle acts up everyday. when im fully stopped my needle drops to like 500rpm's and sometimes it feels like the engine wants to shut offand even when i step on my brakes at a light or whatever when im fully stopped the idle drops a lot... i have a b16, anybody has any ideas? by the way the spark plugs are good i've change them and still does the same ****, spark plug cables are good, dist. rotor new, oil is good..any ideas?
Old Aug 29, 2006 | 05:34 AM
HNP's Avatar
HNP
Default Re: idle acting up... (HNP)
bump
Old Aug 29, 2006 | 05:58 AM
-Gary-'s Avatar
IACV
Idle Air Control Valve, have you checked it out?
Old Aug 29, 2006 | 05:59 AM
instructor74's Avatar
do a search for idle problems. there are a number of post on how to fix this problem it is more than likely going to be a clogged screen on the icv near the intake manifold
Old Aug 29, 2006 | 06:00 AM
-Gary-'s Avatar
Default Re: idle acting up... (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">do a search for idle problems. there are a number of post on how to fix this problem it is more than likely going to be a clogged screen on the icv near the intake manifold</TD></TR></TABLE>
I'm pretty sure it's on the Throttle Body.
Old Aug 29, 2006 | 06:48 AM
Default Re: idle acting up... (-Gary-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- &raquo;</TD></TR><TR><TD CLASS="quote">
I'm pretty sure it's on the Throttle Body.</TD></TR></TABLE> You are right about that I had a brain fart as to where it was located when I typed it this morning the only thing that came to me was near the intake manifold
Old Aug 29, 2006 | 06:55 AM
-Gary-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote"> You are right about that I had a brain fart as to where it was located when I typed it this morning the only thing that came to me was near the intake manifold</TD></TR></TABLE>
No biggie. I just didn't want us to steer the guy wrong.
Old Aug 29, 2006 | 07:39 AM
HNP's Avatar
HNP
thanx guys, i need to get working on this because the car looses some power and i dont like that....
Old Aug 29, 2006 | 10:15 AM
HNP's Avatar
HNP
anybody has a picture of the icv, i know is near the mani but i dont know exactly what it is or where is it...thanx
Old Aug 29, 2006 | 10:24 AM
cmck_12's Avatar
also check the tps sensor
Old Aug 29, 2006 | 11:14 AM
-Gary-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HNP &raquo;</TD></TR><TR><TD CLASS="quote">thanx guys, i need to get working on this because the car looses some power and i dont like that....</TD></TR></TABLE>
I hate to ask, but when was the tast time you checked out your plugs and wires?
Old Aug 29, 2006 | 12:11 PM
HNP's Avatar
HNP
i checked the plugs and wires about a month ago thats when i replaced them and it still does the same thing
Old Aug 29, 2006 | 02:25 PM
HNP's Avatar
HNP
so anybody knows where i can find the icv??? pic or something would help since i never dealt with it...thanx
Old Aug 29, 2006 | 02:37 PM
Nocturnal's Avatar
I'd like to know too! Is the IACV located the same place on all engines or does it depend on what motor?
Old Aug 29, 2006 | 02:38 PM
HNP's Avatar
HNP
Default Re: (Nocturnal)
haha im not the only huh...well i have a jdm b16..anybody??
Old Aug 29, 2006 | 02:59 PM
HNP's Avatar
HNP
Default Re: (HNP)
damn someone has to have a pic or something.....
Old Aug 30, 2006 | 07:37 AM
cmck_12's Avatar
Default Re: (HNP)
there is a thread on here about cleaning your iacv so search it also has the pics u want
Old Aug 30, 2006 | 08:04 AM
edmsol's Avatar
Default Re: (HNP)
http://www.ef-honda.com/ben/Badidle.php
Old Aug 30, 2006 | 08:15 AM
ballerchild's Avatar
i'm having the same problem on the same motor.. let us know if cleaning the IACV fixed it.. gl
Old Aug 30, 2006 | 02:37 PM
HNP's Avatar
HNP
Default Re: (HNP)
thanx a lot guys i really appreciated....
Old Aug 30, 2006 | 02:47 PM
lemon_juice's Avatar
Default Re: (HNP)
to get at your iacv its better to remove the entire throttle body unless you have a 96-00 civic dx which will be in the intake mani.
with the tb off, the iacv is on the bottom of the tb and held there with 3 bolts. after removing those you can clean that with carb cleaner or something and put it back...it also may need to be adjusted some i forget how to do that but youll have to completely take it apart...well almost by unscrewing the inside.
Old Aug 30, 2006 | 03:19 PM
philosofy1's Avatar
Default Re: (HNP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HNP &raquo;</TD></TR><TR><TD CLASS="quote">haha im not the only huh...well i have a jdm b16..anybody?? </TD></TR></TABLE>
if it's the jdm one, then it's on the top of the intake manifold, to the right near the fuel pressure regulator.
Old Aug 30, 2006 | 03:46 PM
Default Re: (philosofy1)
yes actualli my bad the fitv is on the tb and the iacv is on the manifold. likely to be the fitv though, as id check that first.
Old Aug 30, 2006 | 04:19 PM
HNP's Avatar
HNP
Default Re: (lemon_juice)
nah i just looked at it and is not necessary to take the tb off to get to the iacv, if this fixes my problem i will post
hell0curry
Apr 4, 2012 11:20 PM
EGIan
10
Feb 11, 2009 07:52 PM
matt_in_sd
Dec 14, 2006 11:58 AM
ej2rider
Jul 9, 2005 06:14 PM
