VAFC2 help
Old Aug 29, 2006 | 07:57 PM
Em1Rookie's Avatar
Default VAFC2 help
ok I set it up the other day in my 00 civic si. then me and my friend started configuring the setup and stuff. Well my buddy unplugged my MAP sensor and my car ran fine. What the hell does that mean!? Then we set my VTEC down to 4800 and it still kicked in at 5500. Does anybody have any diagnosis for either problem?
Old Aug 29, 2006 | 08:00 PM
BlueIntegraBoy's Avatar
Default Re: VAFC2 help (Em1Rookie)
Did you hook it up correctly?
Old Aug 30, 2006 | 08:25 AM
Em1Rookie's Avatar
yeah I hooked it up right, I double checked everything
Old Aug 30, 2006 | 08:38 AM
cashshoes's Avatar
when you hook it up you dont just splice it into the ecu wires you have to cut them like the books says like this
vtec from ecu cut vtec to solinoid
i think purple i think pink
you have to do all like that it says witch wire goes to the ecu and witch wire goes to the car
Old Aug 30, 2006 | 01:07 PM
Em1Rookie's Avatar
yeah I cut the VTEC and the Pressure wires. I printed out the wiring diagram from Apexi's website.
Old Aug 30, 2006 | 01:21 PM
cashshoes's Avatar
ok well then you prob got the wrong ecu but if you dont then you can cut the vtec solinoid wire and run the wire from the vtec controller to the vtec solinoid same for tps and map for tps it is the middle wire i think dont quote me on that and the map sensor is the middle to dont quote me on that neather cause mine i had to connect it straight to the sensors and i heard conecting it to the senors is a better signal 2
Old Aug 30, 2006 | 05:23 PM
Em1Rookie's Avatar
The reason I know I connected everything right, is because the guy that had the car before me had all kinds of **** on the car before he sold it to me. But when he had it for sale, it went all back to stock. So I just tapped into the taps he already had on the ECU. All I had to do was double check everything against the Apexi wiring diagram. So I know it's NOT wired wrong...
Old Aug 30, 2006 | 05:38 PM
Sr420Det's Avatar
go to settings, etc, cylinders and make sure urs is set at four with the arrow pointed towerds two oclock
Old Aug 30, 2006 | 05:39 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Em1Rookie &raquo;</TD></TR><TR><TD CLASS="quote">ok I set it up the other day in my 00 civic si. then me and my friend started configuring the setup and stuff. Well my buddy unplugged my MAP sensor and my car ran fine. What the hell does that mean!? Then we set my VTEC down to 4800 and it still kicked in at 5500. Does anybody have any diagnosis for either problem?</TD></TR></TABLE>
1. Why do you want ot lower VTEC?
Old Aug 30, 2006 | 05:54 PM
Bangher4$'s Avatar
Default Re: VAFC2 help (G2 Speed)
yeah, why?
toss that thing in the trash, its not going to help you ANY.
well maybe just get your money back. when your engine requires stuff that the vafc will do then its time to convert to obd1 and tune that **** on a dyno. VAFC are trash.
im in idiot though so who knows
Old Aug 30, 2006 | 05:56 PM
THC07's Avatar
Default Re: VAFC2 help (Bangher4$)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bangher4$ &raquo;</TD></TR><TR><TD CLASS="quote">yeah, why?
im in idiot though so who knows</TD></TR></TABLE>
i must also be an idiot
94eg'n
Sep 24, 2007 04:09 PM
05 S2K Stoner
Oct 28, 2004 06:40 AM
eazye5591
Dec 27, 2003 03:22 AM
SuperNemeSis
Mar 29, 2003 02:32 PM
