Code 24
My car has been throwing this code forever and i cannot figure out, i believe its the code for the timing, but the car runs just fine and then code never goes away, tried reseting the ecu and nothing, im really tired of my check engine light lit up, anyone have any ideas?
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
24 only happens to 95dxb18c1
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
there is no 24
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
there is no 24
is there a pause between the 2 if there is you are getting codes 20 and 4 which is
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
there may be, ill have to recheck tom, the motor is an obd2 motor which HAD the crank position senser which i removed, motor has been converted to obd1, and what is electrical load dector?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxb18c1 »</TD></TR><TR><TD CLASS="quote">ok, the first light flashes, pauses for a second then the second light lights up for a second then directly after it flashes 4 times quickly, so that means its code 1 and 14 isnt it?</TD></TR></TABLE>
so it sounds like codes 1 and 14 which is your o2 sensor and the IAC sensor have you check them and tried swapping them out with new ones???
Racersky
Apr 29, 2006 02:31 PM
