Bad water pump I guess?
Old Aug 30, 2006 | 01:31 PM
Mugen112's Avatar
Default Bad water pump I guess?
I have a 1993 civic coupe ex. It has a b18c gsr with a t3/t4 turbo on it. I'm not sure if its my water pump or my radiator but it gets hotter than usual when just crusing over 50 mph (hwy speeds). It has a brand new thermostat and a brand new oem style radiator. I was thinking that the small oem style radiator (single core) wasn't cooling off enough, but then I just realized today that my engine is getting hot without driving much at all. Does this mean I have a bad water pump about to go out?? The fluid is pretty much new so I doubt that would be the problem. Thanks for any feedback.
Old Aug 30, 2006 | 01:34 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Bad water pump I guess? (Mugen112)
1.) this is one of those situations where you should have purchased a huge-core eBay aluminum radiator due to your particular heat-output.
2.) it is also possible that the water pump is going out - and one of the many symptoms is the kind of overheating you describe - but it's more likely the super-heat-soaking you're giving to your thin-*** OEM style radiator
solid180sx
10
Dec 24, 2008 04:48 PM
hondaprodigy
19
Sep 8, 2008 07:14 PM
92civicx
Sep 18, 2007 07:08 AM
standbackimapro
Dec 15, 2005 10:42 AM
