Charcoal Canister
Old Aug 29, 2006 | 07:56 PM
leeminho86's Avatar
Default Charcoal Canister
I bought a JG Edelbrock tb a while ago and since I've installed it I've had a surging idle when the engine warms up. There was a line running from the top of the oem tb to the charcoal canister that the new tb didn't have a place for, so I left it hanging. Just wondering if that would have anything to do with it? The edelbrock cancelled out the FITV so I can't adjust that, new sensors came on the tb so I don't believe it's that, just wondering if it's that line, and if so where should I re-route it too? I've heard of people removing the canister completely but it's always up for debate, so any insight would be greatly useful.
Old Aug 29, 2006 | 09:24 PM
Frozen E's Avatar
H-T White Ops
removing the canister shouldn't mess with your vacuum at all. It's pressure out of your crank case. More than likely you messed up when you bolted the TB up and have a slight leak. Look for it with some brake cleaner.
Old Aug 29, 2006 | 11:24 PM
NA_H22_Ej's Avatar
Default Re: (IslandSi)
maybe u messed up the TB gasket
Old Aug 30, 2006 | 09:34 PM
leeminho86's Avatar
Default Re: (NA_H22_Ej)
Ahhh I didn't know that would effect it. Ya I just re-used the old one so I'll start there. Thanks for the help
Old Aug 30, 2006 | 11:02 PM
NA_H22_Ej's Avatar
Default Re: (leeminho86)
no problems good luck, make sure theres no cracks in them, they're really fragile..
Rasmusm
Apr 19, 2015 08:09 AM
_MMR_
Feb 10, 2014 05:57 PM
93k20z1hatch
Aug 30, 2008 04:44 PM
e30FTMFW
Aug 3, 2008 12:03 PM
snouka
Jun 19, 2005 09:25 AM
