diffrence between hx and ex
Old Aug 29, 2006 | 07:10 PM
cashshoes's Avatar
Default diffrence between hx and ex
what are diffrences between hx dizzys and ex dizzys i have a ex head with a hx dizzy was working fine untill i shaved the head 20 mills took it to autozone so they could do the obd2 test and it says i am misfiring in cylinders 2,3,4 what could cause this thinking it is the dizzy but dont know. this is what i have
new spark plugs
8.5 new wires
new rotor button
new dizzy cap
wilco fuel pump(would this be the prop sense before i had ITBs on and now have factory manifold back on)
Modified by cashshoes at 2:41 PM 8/30/2006
Old Aug 30, 2006 | 08:20 AM
cashshoes's Avatar
bump
Old Aug 30, 2006 | 10:17 AM
BigRonDawg's Avatar
Default Re: (cashshoes)
If only i could understand... I'm sure people who could help you feel the same way. Read your first post out loud to a friend. Tell me if they understood.
Old Aug 30, 2006 | 11:18 AM
all_conference's Avatar
Is there a translator here?
Old Aug 30, 2006 | 11:29 AM
Turbo_y8's Avatar
Default Re: diffrence between hx and ex (cashshoes)
you shaved the head 20mill. WTF!!! You need to proof read, and use spell check. No one can help you if no one can read or make sense of what your trying to say?
Old Aug 30, 2006 | 11:53 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cashshoes &raquo;</TD></TR><TR><TD CLASS="quote">what are diffrences between hx dizzys and ex dizzys was have a ex with a hx dizzy was working fine untill <FONT COLOR="red">i shaved the head 20 mills</FONT> took it to autozone so they could do the obd2 test and it says i am misfiring in cylinders 2,3,4 what could cause this thinking it is the dizzy but dont know. this is what i have
new spark plugs
8.5 new wires
new rotor button
new dizzy cap
wilco fuel pump(would this be the prop sense before i had ITBs on and now have factory manifold back on)</TD></TR></TABLE>
If the bold, red text means you shaved 20 millimeters off the head, that's a problem. If you took 20 thousandths off the head - a more normal amount to be sure - that's probably STILL your problem.
What the expletive makes you think it's the distributor when you've fucked around with the head shape and compression of the motor? Do you have tuning or datalogging to determine the temperature or air/fuel you're getting? Are you running high enough octane for the bump in compression? Are you mentally retarded?
All this and more on the next Maury.
Old Aug 30, 2006 | 12:31 PM
BlackHXCoupe's Avatar
Default Re: diffrence between hx and ex (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
All this and more on the next Maury.</TD></TR></TABLE>
Maury Maury Maury!!
Old Aug 30, 2006 | 09:08 PM
Default Re: diffrence between hx and ex (BlackHXCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackHXCoupe &raquo;</TD></TR><TR><TD CLASS="quote">Maury Maury Maury!! </TD></TR></TABLE>
Chants along with the crowd.
What a funny thread.
Old Aug 30, 2006 | 10:22 PM
crwilliam82's Avatar
Default Re: diffrence between hx and ex (all_conference)
Maury Maury Maury!!
mushu315
14
Mar 30, 2005 10:16 PM
Xxcivic99xX
Aug 4, 2004 06:25 AM
civicnar
18
Jan 15, 2004 07:36 PM
DragII
May 4, 2002 11:50 AM
