how do i remove my power mirror on my 93 del sol?
Old Aug 30, 2006 | 01:20 PM
scory's Avatar
Default how do i remove my power mirror on my 93 del sol?
i have absoulutely no idea on how to remove it. My old one is broken...and i'm replacing it with a new one. Also will my fuse blow when changing the mirrors?
Old Aug 30, 2006 | 01:40 PM
Archidictus's Avatar
Unceasing Measure
Default Re: how do i remove my power mirror on my 93 del sol? (scory)
There should be a triangular panel at the top of your door panel near the mirror. Remove that by gently prying. Underneath there should be three 10 or 8mm nuts (I don't remember which) that you need to remove. After that, the mirror should be physcially free of the door. Unclip the wire harness and you're all set
Good luck.
Old Aug 30, 2006 | 04:53 PM
dthug's Avatar
Default Re: how do i remove my power mirror on my 93 del sol? (Archidictus)
8mm
Old Aug 31, 2006 | 06:35 AM
Phillyhatch's Avatar
Remove your door panel. there is a screw in the in the front top corner. remove that and the plastic piece its holding in. There is a plastic screw clip just below that remove that also. There is a screw in the door handle and one behind the door pull. just pop the plastic plug out to access the screw. pull the door panel out from the bottom and then lift it up. there are three nuts holding the mirror on. You will need an extension to get to them, not sure what size socket you need. Just unplug the harness remove the nuts and pull out the mirror. just reverse everything for installation
inaety
Aug 24, 2008 06:39 PM
themurrell
Feb 21, 2007 08:32 PM
txl146
Apr 7, 2005 04:31 PM
vulgar_si
Jul 3, 2003 11:25 AM
eddie1681
Feb 24, 2003 10:33 PM
