Code P1457, Idle all over the place
Old Aug 29, 2006 | 06:45 PM
premo_si's Avatar
Default Code P1457, Idle all over the place
Car is a 2000 Si. THe car sat for about a year, and I just rebuilt the bottom end. It's running excellent, with the exception of this code. I reset it, and somehow managed to pass my emmissions inspection.
Basically, I can't get the idle to stay at the same place. I turned the screw, and had it around 750, but now it bounces all over. Sometimes its high, sometimes it feels like its going to stall out. Theres been a few times when I stop at a redlight or park and let it idle, the check engine light comes on, and the idle immediately jumps to 1500 rpms, and holds steady there. THen when I drive it like that, the car seems unable to hold a constant speed. And when I step on or off the gas, the car bucks a little. And the RPMS drop alot faster than normal.
I know this is a lot of random BS, but I was wondering if anyone had any ideas as to what it was. I know that code P1457 is the EVAP system, and I was thinking I have a vaccum leak somewhere. I was hoping that with the specifics I gave, someone else has had this problem. Thanks in advance
Old Aug 29, 2006 | 06:53 PM
EGwhat!!!'s Avatar
Default Re: Code P1457, Idle all over the place (premo_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helms &raquo;</TD></TR><TR><TD CLASS="quote">code P1457-EVAP system leak detected in canister area</TD></TR></TABLE>
i would start there
Old Aug 29, 2006 | 07:33 PM
cambopheonix56's Avatar
Default Re: Code P1457, Idle all over the place (EGwhat!!!)
Vacuum line somewhere. That would probably cause that code and a bad idle.
cartune network
Apr 1, 2016 01:02 AM
xfactor4774
Apr 17, 2014 12:28 PM
c0nspire
Feb 23, 2006 02:09 PM
russian_racer
Jun 28, 2003 02:01 PM
