Rear Suspension Problems on 99 Si
Old Aug 30, 2006 | 04:16 AM
killa99si's Avatar
Default Rear Suspension Problems on 99 Si
I bought a set of rear lower control arm for my Si since I was rear ended an one twisted and the other on bent. I am having trouble getting the bolt that connects to the sway bar off, as well as the one to the back of the rotor. Also I had a small animal chew up some of my grounding wires and was wondering what the best wires I could go with were. Thanks.
Old Aug 30, 2006 | 08:16 AM
CardDealer's Avatar
Banned
Default Re: Rear Suspension Problems on 99 Si (killa99si)
Modified by CardDealer at 9:20 AM 11/16/2006
Old Aug 30, 2006 | 08:39 AM
rmcdaniels's Avatar
For the sway bar you need to use a box wrench on the nut and hold the middle part in place with an allen wrench.
Old Aug 31, 2006 | 04:19 AM
killa99si's Avatar
Default Re: Rear Suspension Problems on 99 Si (rmcdaniels)
thanks, that helps.
HT Chaplain
Jan 6, 2006 11:20 AM
vtecman
Jun 3, 2004 07:22 AM
Civic44
Jul 8, 2002 06:15 AM
dynomite55
Sep 11, 2001 07:52 PM
