the PIN!!!!
You need to hit it with something that's the same size to keep the head from mushrooming.
Sounds like it's too late for that, so keep beating the **** out of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nicaraguense13 »</TD></TR><TR><TD CLASS="quote">i heard their is a certain size puncher that fits???? and from any of the two side i can hit it?? </TD></TR></TABLE>
from the bottom of the tranny.
ummm use a 1/4" or 8mm punch
r u tryin to put in a short shifter...cuz u dont need to do all that ...it makes it easier ...but possible with out removing it
8mm or 1/4" punch for roll pin/spring pin. Or this: http://www.matcotools.com/Cata...51164
An air hammer also works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cKoupe »</TD></TR><TR><TD CLASS="quote">8mm roll pin punch is the right tool, but the ac compressor bracket bolt with the point works perfect if your in a jam, thats what I always use.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">8mm or 1/4" punch for roll pin/spring pin. Or this: http://www.matcotools.com/Cata...51164
An air hammer also works.</TD></TR></TABLE>
I took a 3/16 nut driver, broke the head apart, and smashed the handle till the shaft came out. When I was done, I had about a 8mm punch and it came out really easy.
So in otherwords, get an 8mm punch lol
The Flying Dutchmen
Nov 14, 2006 12:34 PM
quicksol95
22
Oct 10, 2004 01:09 PM
jondancer
10
Apr 15, 2003 01:05 PM
