leak in engine bay
Old Aug 30, 2006 | 10:42 AM
pangitngeh2's Avatar
Default leak in engine bay
well i have a leak somewhere and i don't know where it is. i changed my valve cover gasket already. looks to be a coolent leak. here are a couple of pics. what could i change to stop the leak? thanks for any help!
Old Aug 30, 2006 | 10:45 AM
lonefuzzy79's Avatar
That looks like coolant and oil. Headgasket IMHO. How many miles? Have you ever changed it? If not I would do some routine maintenance. Headgasket, timing belt, water pump etc.
Old Aug 30, 2006 | 10:47 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: leak in engine bay (quas)
Headgasket is done
Old Aug 30, 2006 | 10:56 AM
turbociviccoupe's Avatar
Default Re: leak in engine bay (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Headgasket is done</TD></TR></TABLE>
Old Aug 30, 2006 | 11:11 AM
Default Re: leak in engine bay (turbociviccoupe)
alright, thanks guys
Old Aug 30, 2006 | 11:13 AM
nsxmatt's Avatar
Check your coolant and engine oil dipstick and see if the two have the same fluid in them.
Old Aug 30, 2006 | 11:15 AM
EJ1 wilcox's Avatar
Default Re: leak in engine bay (nsxmatt)
Could it be leaking from the bottom of the water neck on the front left side of the head?
It's pretty unusual for a head gasket to leak externally like that without leaking internally as well. It's possible yes, but I would definately check the more likely stuff first before I assume it's a HG.
Old Aug 30, 2006 | 11:19 AM
nsxmatt's Avatar
Default Re: leak in engine bay (EJ1 wilcox)
I thought that too but it would be all green and it seems to be oil mixed and the block looks clean.
Old Aug 30, 2006 | 11:49 AM
Archidictus's Avatar
Unceasing Measure
That's disgusting. Enjoy changing that head-gasket and make sure you check for flatness of the deck surfaces before you throw it back together, as one of the only reasons you'd get that kind of mixture coming out of the engine is if there was a crack or severe warping in one or the other pieces (head or block).
Old Aug 30, 2006 | 11:13 PM
Default Re: leak in engine bay (Archidictus)
hmm so it is the headgasket? i haven't noticed any problems. runs fine and everything. if it isn't the headgasket, what else could it be? this is the only place i have noticed the leaking also. i just don't have the time to change the headgasket right now with school and work so i'd like to know for sure if it is or not. thanks guys
also, wouldn't a blown headgasket throw a code? i am not throwing any codes at all either. the motor runs fine, just this leaking.
Old Aug 30, 2006 | 11:16 PM
L33TsAbabyEater's Avatar
Could be a waterneck leak but it is most likely a bad head gasget... Both probably need to be replaced since that single cam looks like it still has the factory gaskets that were new in the early to mid 90's...
Old Aug 30, 2006 | 11:21 PM
YodajdmEK4's Avatar
Default Re: leak in engine bay (WhiteBread)
NASTY!! Headgasket for sure, good luck changing it.
hkboy87
Oct 9, 2008 10:53 AM
turbo_b16_ex
12
Oct 6, 2005 01:17 PM
GSRcivicGSR
15
Mar 26, 2005 03:40 PM
snt78
Nov 16, 2004 02:52 AM
ithrowpoop
Jun 12, 2003 03:19 AM
