noobie question
Old Aug 30, 2006 | 01:14 PM
j_dawg22's Avatar
Default noobie question
hey sup h-t im new to the honda scene. I looked at this site hundreds of times for help and info. I have a Eg hatch with a jdm b16a and i/h/e. I was driving and all of a sudden my check engine light comes on, my vtec stops working and my speedometer starts jumpin up and down like crazy. I wished mine guages with a friends and same **** happened again..someone help plz!!!
Old Aug 30, 2006 | 01:19 PM
Archidictus's Avatar
Unceasing Measure
Default Re: noobie question (j_dawg22)
...what code is the check engine light giving you? This isn't rocket science, dumbass: just pull the code and fix the problem. We can't magically tell you what's going on if you keep this kind of information to yourself
Old Aug 30, 2006 | 01:27 PM
nonsense's Avatar
Might be the VSS, pull the code
Old Aug 30, 2006 | 01:28 PM
blksir2's Avatar
check the distributer you might have a loose wire or replace the coil and the ignition module... that should fix it,,,also before you do all that read the code..if anything else just instant message me..
Old Aug 30, 2006 | 01:41 PM
blksir2's Avatar
Default Re: noobie question (Archidictus)
ohhh yeah check also the ecu ground wires by the thermo switch area and make sure is properly grounded..
Old Aug 30, 2006 | 01:46 PM
-Gary-'s Avatar
Default Re: noobie question (blksir2)
This is why I'm scared of swapps.
It just adds som many more things to go wrong when things do go wrong.
Old Aug 30, 2006 | 02:31 PM
j_dawg22's Avatar
hey thanks for the quick response... i pull the code later 2morrow.... i know my bad for lack of information thanks all the same
Old Aug 30, 2006 | 02:43 PM
blksir2's Avatar
smokey68321
27
Nov 16, 2009 06:03 PM
TcUiRvBiOc
Aug 16, 2007 03:54 PM
si 1
Mar 31, 2006 12:35 PM
sexyblack93lude
Oct 24, 2005 04:08 PM
halfNhalf-83
Mar 15, 2004 10:00 AM
