Help !!! del sol vtec high idle
Old Aug 30, 2006 | 03:26 PM
Green B16Sol's Avatar
Default Help !!! del sol vtec high idle
I have a 95 del sol vtec that i bought about a month ago. The car had a dc sports header, bored out throttle body, short ram intake and weld on muffler. after driving for a few days i noticed the car had a lack of low end power and idled a little low. i decided it was due to the bored throttle body being to big, and or not properly done. after looking further i noticed the idle screw was all the way in so i backed it out some. this brought back some low end power but caused the idle to be way to high. i replaced the throttle body with an obd 0 one, only to have the same problem. with the idle screw all the way in the car idles at about
1100-1200 rpm. i cleaned and swaped the iacv but nothing changed. when i cover the hole for the iacv in the throttle body the car idles down, like something is telling the iacv to open too much.
Any help would be greatly appreciated
Old Aug 30, 2006 | 03:33 PM
philosofy1's Avatar
Default Re: Help !!! del sol vtec high idle (Green B16Sol)
being that you removed the T/B, try re-adjusting your throttle cable, it's probably to tight.
Old Aug 30, 2006 | 03:46 PM
Default Re: Help !!! del sol vtec high idle (philosofy1)
Tried that, Thanks though
Old Aug 30, 2006 | 05:15 PM
bump....
fog raw
Dec 14, 2011 09:15 PM
black bandit
Jan 14, 2008 04:26 AM
FatBoy4door
Oct 20, 2004 09:17 PM
B-Series Sol
Sep 3, 2002 11:56 PM
ShortbusEK
12
Apr 8, 2002 02:58 PM
