Rear swaybar install - subframe
Old Aug 29, 2006 | 02:30 AM
Eyal 951's Avatar
Default Rear swaybar install - subframe
Is the subframe already tapped for the D brackets on the rear sway bar, or do I need to do anything?
Old Aug 29, 2006 | 03:20 AM
Miracle's Avatar
Default Re: Rear swaybar install - subframe (Eyal 951)
I am not sure about the older Civics, but on the 01-05, anything less than an EX did noot come predrilled with spots. They make an adapter kit for it.
With that being said, I think 96-2000, any non-Si did not come with it. Somebody correct me if I am wrong.
Old Aug 29, 2006 | 04:58 AM
sicones's Avatar
Default Re: Rear swaybar install - subframe (.Red.EM2)
all 96-00 is a direct bolt on, all the holes are there, 92-95 may need lower control arms depending on the trim
Old Aug 29, 2006 | 06:55 AM
instructor74's Avatar
Default Re: Rear swaybar install - subframe (sicones)
on the 92-95 the sub frame was already drilled for the mounts. You will need the lower control arms for the swap the only civics that had the control arms set up for a sway bar already had one. Acura Integras from 94 and up had the correct parts and are a direct fit to the car. Also I was told the 4dr civic ex had a rear sway bar
Old Aug 29, 2006 | 10:02 AM
Eyal 951's Avatar
Default Re: Rear swaybar install - subframe (instructor74)
ok, thanks guys. I have the control arms already (Full GSR swap front and rear) Just wanted to know if its a bolt on affair. Any tear out issues with a s tock gsr bar? I will use an asr brace when I change to usdm ITR, but for now, the small 13mm shouldn't be an issue correct?
Old Aug 29, 2006 | 11:45 AM
BlueIntegraBoy's Avatar
The GSR sway shouldn't be a problem.
Old Aug 29, 2006 | 11:48 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Rear swaybar install - subframe (BlueIntegraBoy)
On an EG, there are holes in the rear subframe already <FONT COLOR="red">but you will have to widen them with a drill bit of the appropriate diameter if the car did not come with a stock swaybar.</FONT>
Just keep that in mind before you get under there and start getting frustrated.
Old Aug 29, 2006 | 11:49 AM
Eyal 951's Avatar
Default Re: Rear swaybar install - subframe (Archidictus)
widening is no propblem I geuss. I just use a nut on the inside?
Old Aug 29, 2006 | 12:10 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyal 951 &raquo;</TD></TR><TR><TD CLASS="quote">widening is no propblem I geuss. I just use a nut on the inside?</TD></TR></TABLE>
yessir
Old Aug 29, 2006 | 04:37 PM
egsleepercivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">On an EG, there are holes in the rear subframe already <FONT COLOR="red">but you will have to widen them with a drill bit of the appropriate diameter if the car did not come with a stock swaybar.</FONT>
Just keep that in mind before you get under there and start getting frustrated.</TD></TR></TABLE>
not always true, my 94 ex already had the holes in the subframe and bolts tack welded on from the factory, I replaced the lca's with teg ones and everything bolted up
gl
08rampage
Jan 31, 2009 05:38 PM
99hondacura
Suspension & Brakes
Jun 28, 2008 08:47 PM
DerangedEG
May 14, 2004 11:48 AM
2camsaam
Nov 22, 2002 05:39 PM
