HELP B SERIES CRANK POSITION SENSOR WIRING PROBLEM
Old Aug 30, 2006 | 05:55 PM
SwapedEX's Avatar
Default HELP B SERIES CRANK POSITION SENSOR WIRING PROBLEM
ok i have a 98 civic ex... now all the wiring matched up fine except the ckp sensor...
my harness has a 3 wire plug on it.. but the b series sensor is a 2 wire connector.. i know some one has had to deal with this before ... please help me..
Old Aug 30, 2006 | 08:09 PM
slammedEM1Si's Avatar
what yr harnes/motor.
Of the top of my head:
you might have incompatible OBD components.
Old Aug 30, 2006 | 08:34 PM
SwapedEX's Avatar
its all obd2... that is what i was trying for..
its a 98 ex which is obd2, and a b16a2 out of a 99 si.. which is obd2
Old Aug 30, 2006 | 09:52 PM
hatchi's Avatar
Default Re: (SwapedEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwapedEX &raquo;</TD></TR><TR><TD CLASS="quote">its all obd2... that is what i was trying for..
its a 98 ex which is obd2, and a b16a2 out of a 99 si.. which is obd2</TD></TR></TABLE>
the 98 ex is obd2a and 99-00 is obd2b.
Old Aug 30, 2006 | 10:09 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (hatchi)
Why not just go OBD1?
If I were you, I would get Helms manuals for your donor engine and your model car. Look up both harnesses and compare wires.
Old Aug 30, 2006 | 10:49 PM
SwapedEX's Avatar
well im running an obd2a to obd2b conversion harness and pt2 ecu... ill go the obd1 route later on.. emissions.. gotta love it.. any way i think i figgured it out.. it runs.. havent had a chance to drive it.. so when i do that tomarro.. ill keep every one posted..
EG6_LS_BOOST
Aug 22, 2013 11:05 PM
Civic483973
12
Jun 11, 2010 08:55 PM
jaredvabeach
Aug 28, 2009 06:24 PM
civictyper99
Sep 26, 2004 06:30 PM
