car died.. replaced distributor, car works.. 2 miles later car dead again?!?
Old Aug 29, 2006 | 01:18 PM
bushfreakz's Avatar
Default car died.. replaced distributor, car works.. 2 miles later car dead again?!?
anyone got any idea why this happened? car was running great with the swapped distributor.. started right up!! now it appears the same thing has happened..
92 civic dx with d16 minime.. has been running fine for 2 years now...
car turns over... no apparent spark coming from the wires... just suddenly stopped while driving.
Old Aug 29, 2006 | 01:21 PM
G2 Speed's Avatar
Default Re: car died.. replaced distributor, car works.. 2 miles later car dead again?!? (bushfreakz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bushfreakz &raquo;</TD></TR><TR><TD CLASS="quote">anyone got any idea why this happened? car was running great with the swapped distributor.. started right up!! now it appears the same thing has happened..
car turns over... no apparent spark coming from the wires... just suddenly stopped while driving.</TD></TR></TABLE>
alternator... battery...
acctual plug wires..
Old Aug 29, 2006 | 01:23 PM
EGwhat!!!'s Avatar
internal coil maybe
Old Aug 29, 2006 | 01:24 PM
G2 Speed's Avatar
Default Re: car died.. replaced distributor, car works.. 2 miles later car dead again?!? (EGwhat!!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! &raquo;</TD></TR><TR><TD CLASS="quote">internal coil maybe</TD></TR></TABLE>
isn't coil in the distributor?
he just replaced it
Old Aug 29, 2006 | 01:25 PM
bushfreakz's Avatar
battery is fine... wires are fine.. alternator should be ok right?
distributor died.. we replaced it 2 hours later.. and car started up.. driving again trying to get to work.. and it dies again.. same symptoms.. still have battery and im actually sitting in the car right now.. i got wifi baby!!!
Old Aug 29, 2006 | 01:26 PM
EGwhat!!!'s Avatar
Default Re: car died.. replaced distributor, car works.. 2 miles later car dead again?!? (G2 Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">
he just replaced it</TD></TR></TABLE>
yeah put doesnt mean he changed it
G2 Speed's Avatar
Default Re: (bushfreakz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bushfreakz &raquo;</TD></TR><TR><TD CLASS="quote">battery is fine... wires are fine.. alternator should be ok right?
distributor died.. we replaced it 2 hours later.. and car started up.. driving again trying to get to work.. and it dies again.. same symptoms.. still have battery and im actually sitting in the car right now.. i got wifi baby!!!</TD></TR></TABLE>
hmm, your spark plugs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! &raquo;</TD></TR><TR><TD CLASS="quote">yeah put doesnt mean he changed it</TD></TR></TABLE>
Old Aug 29, 2006 | 01:33 PM
EGwhat!!!'s Avatar
Default Re: (G2 Speed)
it wouldnt hurt to check... have you checked all you grounds???
Old Aug 29, 2006 | 01:34 PM
bushfreakz's Avatar
you just hear it cranking there is no jumpin like it wants to start at all... there is 0 spark
Old Aug 29, 2006 | 01:35 PM
bushfreakz's Avatar
is there anything that can cause a distributor to go bad? something else electrical?
i think something may have blown out both distributors
Old Aug 29, 2006 | 01:46 PM
fucjdm
Guest
Posts: n/a
honda distributors are notorious for having bad control modules internally... So they go bad rather spotaneously... Specially the rebuilt ones like Autozone
Old Aug 29, 2006 | 02:05 PM
vlc92189's Avatar
did you replace the WHOLE distributor? including the ignition coil? he might of just replaced the cap and rotor.. the ignition coil runs about 80 bbucks.. pulll spark plug out.. hold it in wire.. and try n crank the car.. but have it grounded. if there is no spark then it ost likley is your ignition coil... they tend to take a **** after a while.. just replaced mine hte other day without no problems.
Old Aug 29, 2006 | 02:19 PM
bushfreakz's Avatar
yes the distributor came out of another car it worked...
and it continued to work for awhile in this other car... i cannot throw it back into the other car now because that car has the head off of it right now.
Old Aug 29, 2006 | 04:10 PM
B18bEG6ick's Avatar
check the resistance of the coil and check the icm too, for proper operation while the coil is still in the car. here is the site http://jdmlyfestyle.com/how_to...m.htm
i had the same problem as you but i got a new distributor from ebay and had everything (worth the money) and it worked after a couple cranks. goodl uck
rodvang
Jan 9, 2008 05:45 AM
redlinexd
Dec 1, 2007 12:33 PM
98jdmek
Nov 29, 2007 01:34 PM
whatcivic
Nov 5, 2007 03:19 PM
gottats25
Jun 29, 2005 05:07 PM
