NEED HELP BAD!! clutch?
my car has been driveing fine.. until today, when the car is started, it wont go into gear, i know its not the sychronizers because when the car is shut off it goes into every gear smoothly, i bled the clutch line, and checked the clutch fork and it IS moving so i'm thinking its the clutch? help me please!! if its not the clutch let me know
So, the car was operating normally until you went to start it one day and it didn't go into gear? Does it just grind or something? The only thing I can think of is that the slave cylinder isn't getting/retaining enough pressure to push the fork far enough to release the clutch disk... or your pressure plate has broken somehow. Look for a leak somewhere either in the line or in/around the master/slave cylinders. Check the underside of the bellhousing and the area under your dash where the master cylinder passes through the firewall. You might end up having to pull the trans and doing a close inspection of the clutch disk/pressure plate assembly.
Maybe someone else knows something I don't, though. Good luck!
i can only do it when it is in neutral, the clutch sensor is on the pedal not the clutch itself, i tried starting it in gear and the car "hopped" it started to move but the e-brake was on and so it stalled... if that helps anyone determine what it is thats wrong..
be4unvme
Jan 1, 2014 06:22 PM
98trooper
10
Aug 22, 2012 05:03 AM
ch0baca
Mar 11, 2009 02:11 PM
