new here
Old Aug 29, 2006 | 11:44 AM
jpizzi's Avatar
Default new here
I have a 97 civic with a d16y7 and swaped it for a d16y8 and I have no vtec. What do I need to do???
Old Aug 29, 2006 | 11:45 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: new here (jpizzi)
Did you swap ECUs as well?
Old Aug 29, 2006 | 11:46 AM
BlueIntegraBoy's Avatar
Did you wire up VTEC?
Old Aug 29, 2006 | 11:47 AM
sicones's Avatar
Default Re: new here (BlueIntegraBoy)
» Search Results
Your search for mini me returned 979 results.
Old Aug 29, 2006 | 11:48 AM
jpizzi's Avatar
I did not swap the ecu but I did swap the entire engine harness
Old Aug 29, 2006 | 11:49 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpizzi &raquo;</TD></TR><TR><TD CLASS="quote">I did not swap the ecu but I did swap the entire engine harness</TD></TR></TABLE>
So let's think about this for a second. We're using a non-VTEC ecu and complaining about VTEC not engaging. I wonder why that is?
Use your head.
Old Aug 29, 2006 | 11:51 AM
cute little bastard
Default Re: new here (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
Use your head.</TD></TR></TABLE>
lol, yeah you need a VTEC ECU in order for VTEC to engage. That should solve your problem. Look for a P2P ECU
Old Aug 29, 2006 | 12:10 PM
jpizzi's Avatar
Default Re: new here (SkoundrelUSA)
Well thats what I thought but was not sure because the engine harness pluged right into my ecu ,but even though some of yall are rude I still say thanks.
Old Aug 29, 2006 | 12:11 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpizzi &raquo;</TD></TR><TR><TD CLASS="quote">Well thats what I thought but was not sure because the engine harness pluged right into my ecu ,but even though some of yall are rude I still say thanks.</TD></TR></TABLE>
And some of yall are stupid, but I still answer your questions
Old Aug 29, 2006 | 12:16 PM
cambopheonix56's Avatar
We are not being rude, just common sense.
Old Aug 29, 2006 | 12:49 PM
cashshoes's Avatar
if you dont have the money to buy a ecu you can always put it on a switch take the solinoid wire it is the one running to the top of the vtec solinoid and cut that get a switch put pos and neg on the switch and put the vtec in the acces spot mount it and boom got vtec whenever you want
Old Aug 29, 2006 | 12:56 PM
hondamark35's Avatar
Default Re: (cashshoes)
almost.... but the effects are not the same, when vtec kicks it does a bit more than trigger the solenoid, if i understand the system right. so a "vtec switch" is a poor idea, get a part time job and do it the right way, you'll be more pleased with your results
anonnonator
Honda Civic (2001 - 2005)
12
Aug 14, 2007 01:37 PM
hondateg10
Mar 1, 2007 07:13 PM
red2genacura
Apr 16, 2006 12:03 AM
hipochevys
Apr 21, 2005 06:54 PM
lmiguelvv
Sep 23, 2004 01:50 PM
