Wiring Harness Help!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 30, 2006 | 05:27 PM
BaconLettuceTomato's Avatar
Default Wiring Harness Help!!!!!!!!!!!!!!!!!!!!!!!!!
Yeah, i swaped in a d16y7 into a 93 coupe that came with the z6. was wondering if im goin to have to swap harnesses?????? help, i need this car running asap!
Old Aug 30, 2006 | 06:30 PM
Default Re: Wiring Harness Help!!!!!!!!!!!!!!!!!!!!!!!!! (bltcivic)
ttt
Old Aug 30, 2006 | 07:28 PM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bltcivic &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, i swaped in a d16y7 into a 93 coupe that came with the z6. was wondering if im goin to have to swap harnesses?????? help, i need this car running asap!</TD></TR></TABLE>
Basicly the only thing you need to use is the block and head on the y7. Everything else use the z6, manifolds, distributor, and harness. Might have to use a p06 dx ecu since your running non-vtec though.
Old Aug 31, 2006 | 11:21 AM
Default Re: Wiring Harness Help!!!!!!!!!!!!!!!!!!!!!!!!! (nsxmatt)
im running hondata s300 so the ecu is no prob. Ive got to switch alternators and i dont think the dizzy will fit so im just going to cut and splice the y7 dizzy. should be running tonight!
Old Sep 1, 2006 | 04:40 AM
chasemyhonda's Avatar
B A N N E D
Distributors should fit. and your old alternator should fit as well. and that means you can keep your stock harness.
If it came down to it just take the IAC off of your z6 manifold and put it on the y7 manifold.
Old Sep 2, 2006 | 07:51 PM
Default Re: Wiring Harness Help!!!!!!!!!!!!!!!!!!!!!!!!! (blindingxenon)
i just cut and spliced the dizzy wiring and switched alternators. Ive got the z6 intake manifold already on the y7. I finally finished running my oil and water lines for my turbo and cranked the bitch up tonight and she idled perfect! It throw a cel but i believe its the vtec code. I'll plug the laptop in, in the morning and find out for sure!
projectpd
11
Oct 16, 2011 02:31 PM
CRXguy_88
11
Mar 1, 2010 03:47 AM
kingmonkey
Feb 16, 2006 08:27 AM
crxnonvtec
Dec 20, 2005 06:14 AM
brbHPR
Feb 7, 2002 09:11 PM
