clutch problems
so i am having clutch problems right now... i called hmotors and they said it might be one of the springs on the clutch that is fucked up
anyway this is what happend... i took it for a drive ran fine... all of a sudden i couldnt go into any gear... and when i try to put it into 2nd the car trys to pull forward... shifting is fine when the car is off...
the thing is that when we did the swap... we exidently let the resorvoir run empty and i have reason to belive its the slave cylinder thats fucked up... we bleed it now and there is no air... but there was a **** load... and when we bleed it, after pressing the clutch down and letting the fluid out... the clutch just stays on the floors doesnt come back by itself... has to be pulled back into position
please help
please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">Did you just answer your own question?</TD></TR></TABLE>
did i?
did i?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meagainsttheworld »</TD></TR><TR><TD CLASS="quote">but if i pump the clutch it works fine and comes back.. but after it is pressed and nipple is loosened and then retintend... the clutch stays on teh floor</TD></TR></TABLE>
It's supposed to. It's not like a brake pedal, there is no vaccuum for it.
...duh.
...duh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">...duh.</TD></TR></TABLE>
so its suppose to stay on the floor...?
im sorry man this was my first swap and im trying to learn
old_school_dohcvtec
Oct 4, 2007 09:47 AM
range
Dec 1, 2003 02:01 AM
