Exedy cerametallic clutch stage 2
Old Aug 30, 2006 | 02:21 PM
vlc92189's Avatar
Default Exedy cerametallic clutch stage 2
Has anyone had any experience with this clutch? and my car is a daily driver.. should i get a thick disk or thin? thatss the only part im worried bout..
Old Aug 31, 2006 | 07:44 PM
818SpoonITR's Avatar
Default Re: Exedy cerametallic clutch stage 2 (vlc92189)
Get a Exedy stage 2 full face clutch
Old Aug 31, 2006 | 07:46 PM
vlc92189's Avatar
whats a full face?
Old Sep 4, 2006 | 01:11 PM
Default Re: (vlc92189)
EXEDY racing clutches with organic friction materials utilize only premium materials to provide maximum resistance to slippage and burst.
EXEDY full face disc organic clutches can also handle modified engines due to the increased clamp loads.
Drivability with EXEDY organic clutches is similar to that of stock clutches. Pedal efforts will be slightly higher due to the higher clamp loads.
As with all EXEDY clutch discs, EXEDY organic clutches feature high capacity spring center dampers designed to reduce drive train shock and impact.
dominicanboi215
Feb 22, 2009 07:02 PM
IgnitionZ055
Nov 11, 2008 05:12 PM
EARLdaSQUIRREL
Oct 12, 2008 10:23 AM
Dave_yd
Mar 26, 2008 04:23 PM
turbotime
Oct 11, 2004 10:24 PM
