EG interior question! help plzzz
Old Aug 29, 2006 | 10:56 PM
nub_pwn's Avatar
Default EG interior question! help plzzz
im putting in a new dashboard, gray to black, in order to do this i have to drop steering column right?
my friend said two bolts i need to take off in order to drop is underneath by the steering column not sure on the socket size...deep socket 14 or 12?
and one more thing im installing carpet what size sockets i need for chair bolts?
Old Aug 29, 2006 | 11:05 PM
t0p_sh0tta's Avatar
Default Re: EG interior question! help plzzz (nub_pwn)
For every honda all you need is 8, 10, 12 and 14mm sockets.
(12 and 14 will be the most common)
Old Aug 29, 2006 | 11:22 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: EG interior question! help plzzz (t0p_sh0tta)
Why are you even asking this? Do you not have a complete socket set?
Old Aug 30, 2006 | 01:15 AM
Harryflores's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub_pwn &raquo;</TD></TR><TR><TD CLASS="quote">not sure on the socket size...deep socket 14 or 12?
Old Aug 30, 2006 | 01:27 AM
lemon_juice's Avatar
someone ask him if he even has a repair manual for the car!
if you do, it should tell you where everything is
Old Aug 30, 2006 | 01:33 AM
BlueIntegraBoy's Avatar
Yes, you'll need to drop the steering column which are 14mm nuts I believe. You'll remove this u-clamp thing. Seats are 12mm bolts.
Old Aug 30, 2006 | 03:55 AM
instrument's Avatar
he's probably renting tools....one socket at a time.
Old Aug 30, 2006 | 04:48 AM
eg ferio's Avatar
yes i believe the seats are 12 and the steering column are 14
Old Aug 30, 2006 | 01:21 PM
d16vteceg's Avatar
Default Re: (eg ferio)
Steering column bolts are 14mm, may have to use deep socket. then you will have two mount bolts on the end, one in the center underneath the vent on top of the dash, and a couple of miscellaneous bolts undereath. Should probably take off glove box. Don't have to but would be good idea. Bolts for seats are indeed 12mm. GL. Also don't try and pull the dash off until you make sure you have all the connections off.
Itzmy91Teg
Jun 12, 2006 03:39 AM
EF9 JAMS!!!
Oct 29, 2005 06:45 AM
SloCivicHMM
Jul 21, 2004 03:16 PM
96civich22
Nov 2, 2003 03:47 AM
Sean EH2
Jul 31, 2003 04:35 PM
