Clutch problems HELP!!!
my car has been driveing fine.. until today, when the car is started, it wont go into gear, i know its not the sychronizers because when the car is shut off it goes into every gear smoothly, i bled the clutch line, and checked the clutch fork and it IS moving so i'm thinking its the clutch? help me please!! if its not the clutch let me know oh and clutch pedal feels fine
was your clutch fine up to this point? how old is it? how did you bleed the clutch? Check for leaks.. if not your slave cylinder may be bad. Try swapping it with a friend to see if it does the trick. I know mine caused this.
range
Dec 1, 2003 02:01 AM
