y7/y8 mini me obd1 distributor questions?
Old Aug 29, 2006 | 04:05 PM
northkai3's Avatar
Default y7/y8 mini me obd1 distributor questions?
car is a 95 cx eg hatch with a y7/y8 mini me. motor is already in. car wont start. i was told that i could use the stock cx distributor. it doesnt work!? searched no help
Old Aug 29, 2006 | 04:14 PM
northkai3's Avatar
Default Re: y7/y8 mini me obd1 distributor questions? (northkai3)
bump
Old Aug 29, 2006 | 04:23 PM
schardbody's Avatar
it should work fine, the problem lies somewhere else. what ECU you running??? obd1 ecu i hope.
Old Aug 29, 2006 | 05:50 PM
Bense's Avatar
they are all the same dizzy.
Old Aug 29, 2006 | 06:13 PM
GreenEHDriver's Avatar
Default Re: y7/y8 mini me obd1 distributor questions? (Bense)
ecu is a p08,
Old Aug 29, 2006 | 06:39 PM
Bense's Avatar
no, the p08 is the jdm d15b ecu.
Old Aug 29, 2006 | 07:49 PM
an obd 2 ecu has to be used even though it was working with the y7
Old Aug 30, 2006 | 10:08 AM
northkai3's Avatar
Default Re: y7/y8 mini me obd1 distributor questions? (GreenEHDriver)
obd1 ecu should work fine. but for some reason its not. i noticed that the fuel pump wasnt priming. so i flashed the ecu and that made the fuel pump prime but it still doesnt start. now im even more confused. after several times of doing this now the gauge clkuster is going crazy. car still wont start but with the ignition on all the way. the speedometer jumps like crazy and makes a very weird but distinct ticking noise coming from under the dashby my feet. and if i trry and crank the motor both the speedometer and tachometer jump like crazy. car worked and ran fine previous to head and manifold swap. had a full y7 in the car previously with obd1 cx distibutor
Old Aug 30, 2006 | 10:21 AM
northkai3's Avatar
anyone
Old Aug 30, 2006 | 11:03 AM
lonefuzzy79's Avatar
You have something wrong in your wiring. The jumping speedo and the ticking is a dead giveaway and the fact that the fuel pump won't prime when you turned the car on also. Go back and check your conections and grounds. I bet this is your problem. The grounds on the thermostat housing especially. For whatever reason, that ground is crucial in these cars. This is where your trouble lies.
Old Aug 30, 2006 | 02:34 PM
northkai3's Avatar
Default Re: (lonefuzzy79)
figured out part of it. apparently their was a alarm wired into all of the wires under the dash. removed the alarm and rewired everything. pump primes and i have spark but the car just backfires. timing is messed up i must have the wrong dizzy.
Old Aug 30, 2006 | 03:24 PM
93civicEX's Avatar
that distributor should deffinitly work, double check your firing order...and your positive that timing is dead on?
Old Aug 30, 2006 | 05:46 PM
Default Re: (93civicEX)
if the timing was off 1 tooth how much of a difference would that be? would it not start?
Old Aug 30, 2006 | 06:19 PM
Serdar's Avatar
Default Re: (GreenEHDriver)
I already told you dew-doo head get the y8 dizzy and some type of jumper (fabricated or brought) then you should be straight
Old Aug 30, 2006 | 08:52 PM
to the top need more information
Old Aug 30, 2006 | 09:11 PM
v8killa91's Avatar
RYWIRE.com is your friend....
89b20crx
Jul 11, 2013 09:43 AM
ef_hybrid
34
Jul 2, 2013 09:41 AM
sobe
Mar 14, 2005 12:26 AM
ScubaStevo80
Jan 11, 2005 09:38 AM
justinau
Sep 1, 2004 12:06 AM
