Two diff del Sol tire sizes??
Sol to Sol
I have a 94 del Sol, and am about to get new tires.
The car has a VTEC emblem on it, but I believe the D16Z6 and the VIN says its just an Si. (and after research with the FAQ, its confirmed as an Si)
It has the Sol fat-5 14" rims.
My question is, why is there a difference in 14" tire sizes for the two models?
Si =185/60/14
VTEC= 195/60/14
Anyone know?
Si =185/60/14
VTEC= 195/60/14
Anyone know?
Re: Two diff del Sol tire sizes??
the different tires sizes are due to differences in the suspension. run the tire size that matches your car. 185/60/14 or something close to it with similar overall diameter. it is not related to engine size
I run the 195's on my 93 Del Sol Si, car runs fine just get a good alignment and remember your speedo will be faster than you're actually travelling by about 3 mph
Just use size 195/55 14
Notice the 55 and not 60 which will put it closer to the exact height of your stock size
Running through a speed trap that notes your speed my speedo is only off 3 mph
I have the same exact car as you and from experience I like the handling characteristics of the 195 vs. the 185s
Your SI suspension can handle the tire with great ease and you'll notice a nicer feel to the car
There should be a sticker in your car (probably glove compartment) that tells you the stock tire size of your car. Getting another size, other than what came stock, will throw your speedometer off.
I have a 95 S that came with the stock size 175//70/13" but I've been running 195/60/14 in the summer and 185/60/14 winter tires for several years. Overall, I like the handling of the wider 195's but the thinner ones work better with snow tires.
Sol to Sol
Thanks for the info guys!
I knew it would throw off the spedo, but I wasn't sure which way it would read.
I'll just go for stock.
(makes me think of the new Honda commercial "Are those FACTORY RIMS?"
"Oh the wheels?? STOCK!" *with a huge grin*)
Sol to Sol
The formula for figuring out tire diameter is the width 17.5 divided by 2.54 times the aspect ratio .70 time 2 plus the rim size 13.
So
a 175/70/13 is 17.5/2.54*.70*2+13=22.65
Just make sure your close and it keeps your speedo close.
So
I suggest keeping the same trend you got going. Possibly look into upgrading to a 15" rim if you want more performance. Si rims look nice on a del
As well, everyone else can see the same thing you did without you pointing it out. There is not a productive reason to respond.
itsmejto
07-13-2008 08:42 AM
techsynthesis
03-04-2008 05:28 PM
