Which OBD2 ALT would fit an OBD1 JDM B18C?
The motor is going into an EJ with OBD2 wire harness.
I am would like to keep it simple since i dont have and OBD1 harness to convert and also an OBD1 or 2 ALT to convert.
and i also know brackets are an issue with this.
So which OBD2 ALT would fit an OB1 JDM B18C?
Re: Which OBD2 ALT would fit an OBD1 JDM B18C?
bump
Ive been going by this but is this true?
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
states "2) find an OBD2 B-series alternator (any 96-01 B-series alternator will do) which makes it PnP to your EWH....(easiest option)"
and if a obd2 ALT does fit my motor ... and i do run an jumper from obd2 to obd1 will there be a conflict?
anyone? well i went out and i got a crv 97 alternator... i started the car... and took off the positive and the car shut off... so im guessing
a) the alternator is bad
or
b) it doest work for my car
but hey atleast it fit
guess ill keep searching.
or
Last edited by sumoneEK; 07-31-2010 at 01:15 PM. Reason: i bought the cr-v cause noone in my area has a integra alt i was told it was the same.
b20mike
07-29-2003 07:25 PM
