how can i tell if my b16a2 came out of A 2000 si
Re: how can i tell if my b16a2 came out of A 2000 si
I'm not bieng rude but I am curious why that would matter?
Sorry I should have thought before I opened my mouth. this is what wiki says that makes me feel silly now.
B16A2
VTEC
Found in:
1992-2000 Honda Civic EDM VTi (EG6/EG9 & EK4)
1992-1997 Honda Civic Del Sol EDM VTi (EG)
1996-1997 Honda Civic Del Sol USDM "VTEC"
1999-2000 Honda Civic USDM Si (EM1)
1999-2000 Honda Civic CAN SiR (EM1)
Displacement: 1,595 cc (97.3 cu in)
Bore×Stroke: 81.0×77.4 mm (3.19×3.05 in)
Compression: 10.2:1
Power: 160 hp (119 kW) @ 7600 rpm & 111 lb·ft (150 N·m) @ 7000 rpm
Transmission: Y21 or S4C
Redline...8500 rpm
Rev Limit...8450 rpm
VTEC Engagement...5,600 rpm
Aluminum Casting
ECU Code: JDM P30 or USDM P2T
B16A2
VTEC
Found in:
Compression: 10.2:1
Redline...8500 rpm
Aluminum Casting
if it has no vins, its safe to assume that it is/was since the a2 was only offered in the em1, youre good
B16A2
VTEC
Found in:
Compression: 10.2:1
Redline...8500 rpm
Aluminum Casting
B16A2
VTEC
Found in:
Compression: 10.2:1
Redline...8500 rpm
Aluminum Casting
I thought the B16 that came in the del Sol VTEC was the a3...
Not sure, can't believe everything you read on wiki. I see at least one thing about the jdm ecu that has me scratchin my head
Crazy Honda Guy
H-T White Ops
It's true. '93-'94 del Sol VTECs came with the B16A3 and '96-'97 del Sol VTECs came with the B16A2.
OP, do you have a VIN at the bottom edge of the front of the block?
Gatoo_11
10-01-2018 12:53 PM
Type 56
31
11-14-2016 02:07 PM
