92 civic cx b20 swap problem
i have a b20b4 swap with out a knock sensor should i get one
i'm using the stock cx wire harness is that okay or should i get a obd1 ls harness
i'm using a p06 ecu
what will i need to completed this swap
i'm using a p06 ecu
Re: 92 civic cx b20 swap problem
U don't need a knock sensor since the ecu ain't gonna ask 4 it and for engine harness use the ls cause the cx has one wire o2 instead as 4 and with the ls harness it should be plug and play and for ecu u can use the p06 but I would much rather recomment a p75
Eric724
04-12-2011 05:39 PM
4d96gsr
01-29-2007 10:13 PM
turboex
06-15-2003 08:40 AM
