Another d16z6 idle issue!! *Mel Gibson roar*
Ok so i just put in a replacement motor for my del sol since the old one had a rod knock, it started up just fine and everything was hunky dory, then the fluctuating idle set in and i havnt figured out what it is yet, im pretty sure all the hoses are good, car only has 97k on it and well taken care of, i put my finger over bottom port on TB and the idle went back to normal, so im guess its the FITV, im unsure because i thought that was for a high idle rather than sparatic like mine is doing, also the car does die when i cover the top hole, so im lost, any help would be appreciated!!
Re: Another d16z6 idle issue!! *Mel Gibson roar*
The FITV closes as the coolant heats up. It lets in extra air for higher idle while the engine is cold. If it still letting air through once the engine is fully heated, then it isn't closing. If that's the case, first make sure coolant is running through it by carefully checking that the FITV to IACV hose is getting hot. Next, search HT for the thread on cleaning and adjusting the FITV. If necessary, you can screw the valve completely closed to disable it until you can get a new one.
i should not own a honda, i found the problem in like 10 mins tonight, the throttle body wasnt tightened down all the way, it was tight, just not enough, car runs absolutely perfect now, thanks for the help anyway delsolproblems, much appreciated
JdmJohnny210
28
12-31-2012 12:08 AM
byronl
06-14-2006 08:26 PM
martingouda
11-24-2005 11:54 AM
