1995 honda del Sol S with a d15b7 questions...
would it be best to wait to swap to a b series motor to start upgrading the engine or is that a good evough engine to just start upgrading?
Re: 1995 honda del Sol S with a d15b7 questions...
if it has a good compression just do the simple mods and make it last. go to a scrap yard an get a b20z b18b and pick up a b16 head and intake used. you could use ls rods with b16 pistons for a little higher compression. do some research theres a million options. you might luck out and find a gsr in the yard. my local yard has had multiples and even da b17 gsr once or twice with less than 150xxx, exaust your resources before you jump into a build
Former Moderator
SolidSpruce
08-27-2003 05:35 AM
