h23 vs b18
h23 vs b18
ok here is my issue i have a 95 eg coupe with a single cam in it right now. im tired of the single cam problems that im dealing with and wanna swap anyways. im looking at an h23 online that needs a rod and bearing set but the guy only wants 250 for the swap minus axles and harness and ecu which no biggy got a p28 and p75 just layin around. on the other hand i have a bare b18a1 block needs decked and internals and main caps have complete a1 head that i planned to port and polish. my other problem is money is tight right now and dont know what to do. can anyone help me make a decision????
Crazy Honda Guy
Re: h23 vs b18
Find your self an undamaged H23 engine and get a H2B swap. It will take longer to save up for, but will make major power....much more than the 1.8L
Re: h23 vs b18
the problem is time right now also though my single cam has a major rod knock due to bad crank. the last time i did the bearings i made sure there was nothing wrong with the crank and yet still ate the bearing apart.
Re: h23 vs b18
If money is tight, then just swap in another single cam and call it a day. Buying engines that need work, because they were likely abused, is a bad way to waste money. Get another D, and then save up $ until you can afford a swap.
Re: h23 vs b18
well i have another crank layin around but its out of a y8 and my bottom end is y7 with z6 head. i had plans to boost the single cam cause im at 9:1. will the y8 crank work in the y7 block with the y7 rods??
