what is wrong with my shift linkage?
I'm not sure if i just need new bushings or what but it's really loose and my 3rd gear also grinds at higher rpm and was wondering if it's my synchronize or what? thanks.
Re: what is wrong with my shift linkage?
looseness is probably the busing at the bottom of the shifter. grinding would be your syncro's. what fluid are you using? if your not using honda MTF try it out and see if you notice any difference. stay away from syncromeshes cuz those would just be a temporary fix and could lead to some serious issues
thanks, how would i fix the looseness? and well i just got my civic so idk which fluid was used but i will check that.
Crazy Honda Guy
shifting and grinding at high rpm into 3rd is common on tranny's with worn syncro's.....gearspeed makes upgraded ones
get a set of polyurethane shifter bushings. There are two different sets, one for D series, one for B, so pay attention. That takes out the slop. The original rubber bushings get weathered and mushy.
If you feel like spending a little money, you could order a new change ball bushing, rubbers, nuts and bolts and such and just make your linkage like new. The parts are fairly cheap from Honda.
get underneath the car and replace the bushing. as far as fluid dont bother checking what was in it since you just bought the car you should just replace aaall fluids.
its only 4 bolts that hold the shifter together and in place. you dont need to get it off the tranny or anything for that
well the person i got it from said it had a new clutch and had papers for it and recently was installed.
you need to check your fluid, and change the bushing, will take 10 mins and save ur trans, id put synchromesh in since its already grinding
very common for worn syncros... 3rd is usually the first to go
88EFhatch
14
06-08-2005 06:11 PM
ProjectDarkBlack
01-20-2005 10:11 AM
