B16 Nightmare problems, tried everything!
sup honda0tech, i wanted to know if anyone has any other solutions to fixing a bad idle
so far ive done the following:
-Cleaned the iacv
-Cleanded the ficv
-Checked tps sensor
-Put a different chip in the ecu (p28) caused the idle to raise to 1500. with the idle screw adjusted all the way
any helpppppp please
-Cleaned the iacv
-Cleanded the ficv
-Checked tps sensor
Re: B16 Nightmare problems, tried everything!
If its to high or to low try loosening the dizzy n tipping it forward or backward. Might help. If it helps a little but not enough then you might need to check the timing to see if its off.
I would try what they both said because there easier, but would still check the timing and the gap on the plugs. Remember cheap plugs are never pre-gapped
check engine light comes on when ignition is turned and then turns off,
no i havent, which should i try covering?
Try changing the trottle body gasket might have a small crack and would cause engine to rev up and Down cause it's getting extra air
b16, changed, engine, everythinghonda, honda, honda0tech, light, markley02, nightmare, pcv, problems, stillcheck, test, tps, valve
