MFPi Problems, idling at 4500rpm
Hi guys, so im gonna expose my problem.
I have a d15b2 dpfi engine, 90hp and i bought a d15b vtec intake manifold that came complete with p08 ecu injectors throttle body etc...
So i wired the ecu, every wire except for the o2 sensor that i still dont have
the four wire one, and the vtec wires (no vtec head)
Then i got myself a dizzy, My old dizzy plug didnt have crank sensor wires (white and orange) so i took them from the ecu
Plug from the new dizzy
The wires that didnt have correspondence, but i wired them to the ecu.
Them o got a tps cuz my manifold didnt have one.
I switched the green and yellow wires in the tps, am i right?
I had bits of gasket in the head so i cleaned it as most as...my patience allowed me
But i left some bits there, and when i tightened it up as mutch as i can, i filled it with water and it was leaking :\
And now after all my idle is at 4000~4500rpm.... do you think that its from a leak in the intake manifold?
One of the nuts isnt tightened up, the bottom one cuz i just CANT tighten it up, i cant reach it, if i do reach it with the wrench it hits the manifold and i cant turn it... wich maybe is giving me a even bigger gap...
Any ideas?
Cheers
PS: If i disconnect the IACV plug my idle goes to 2000, but if i accelerate it blops, like stalls lol like is too much air going in and no fuel or something...with iacv connected its at 4500 but if i press the gas it accelerates even more, doesnt stall
Any ideas?
Cheers
Re: MFPi Problems, idling at 4500rpm
If your throttle plate is not stuck open, then you have a massive intake air or vacuum leak. As verification, try to kill the engine by covering the top of the throttle body. If the engine does not die, there's a big air leak.
I must have a massive airleak cuz i have tried that methood and the engine doesnt stall...i thought there may be some other way of air getting in but if you say that if i cover the throtle body it should die...that its a leak!
mugenhatchie
02-24-2007 01:00 PM
stehigs321
13
11-29-2003 04:02 PM
Firedrake
10-30-2002 04:56 AM
