car wont go into gear when it on or off
K i just put a new tranny in my hatch. Motor is a b18b1 with a b16 tranny.
I put in a new throwout bearing and installed it right too.
It is very hard to put in a gear, i have to slam it in.
I put all new bushing and a new bitch pin in the shift linkage..
if i adjust my clutch pedal do you think that will help?
new slave cylinder was installed and clutch has been bled plenty of times.
Im stuck and i cant drive my car to work. PLEASE HELP
Re: car wont go into gear when it on or off
Did you put the clutch in right? Is it Cable type clutch or hydraulic clutch? If cable make sure you adjusted it right and if it's hydraulic make sure you bleed it right.
it can be cause you tighten your shiftlinkage to much hahah simple problem happen'd to me and alot of people i know
vietnamese0utlawz
10-11-2006 04:53 PM
